LED Under Cabinet
FusedLight
Hi Eric...
Just try to find a pre-made element that I can drag'n'drop onto my plan.  I've got the cabinets placed, now I want to stick some strip lights on the bottom of them.  I suppose I could add some sort of "placeholder" lamp, but it would be nice if there was a little widget that would do the magic for me.
  • 8 months later...
Draw your cabinets. Go to the library and enter "lighting." There should then be a folder that says "Architectural Lighting." Select that, then cabinet lighting, then tube or your preference. Then drop it in your wall cabinet and it will be there. It may be different depending on which program you are using, which is why it is helpful to adjust your signature to have that information always there.
  I would just use the under-cabinet lighting and just modify the dimensions of them by double clicking on them or use the open properties icon to change the settings of the lights. Like the lights I have in the image attached......you can set the lumens for the lighting too.
