jplee123 Posted July 23, 2019 Share Posted July 23, 2019 Hello. I have a rough home design for which I'm nearing completion of external wall and roof design. However, the roof will not build correctly using the auto-rebuild feature. My goal roof design is simple - The front portion of the house (where porch is, towards the right) exists and is covered by a 10x12 pitch roof. The current ridgeline exists as it shows in the drawing. I'm adding to the rear (where the deck and garage are located, on the left of the plan), and would like a simple gabled roof with a shallower pitch (2 x 12) that should meet with the existing roof aft (to the rear) of the current roof's ridgeline in a clean "T". PROBLEMS: 1) for some reason the rear roof stops "gabling" just over the staircase, and appears to turn into a high shed style roof as it approaches the existing roof's ridgeline. 2) one wall appears to jut out the top of the existing roof like a shark's fin. 3) The existing roof appears to be split with the ridgeline not being continuous, but rather broken about 1/3 of the way through. I have been working on this problem for 2 full days and have tried manipulating just about every wall to correct this issue. I would appreciate any help you can provide. Thank you! Jay. I've uploaded both zipped and unzipped versions of my .plan file (same .plan file in the zip) for your downloading options. ArchitecturalPlan06b-2floor.zip ArchitecturalPlan06b-2floor.plan Link to comment Share on other sites More sharing options...
solver Posted July 23, 2019 Share Posted July 23, 2019 Like this? (done manually) Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 23, 2019 Share Posted July 23, 2019 I programmed the attached, edited plan file so it can still be opened and worked in Architectural. DJP ArchitecturalPlan06b-2floor.zip Link to comment Share on other sites More sharing options...
jplee123 Posted July 23, 2019 Author Share Posted July 23, 2019 35 minutes ago, solver said: Like this? (done manually) Yes. Exactly! Link to comment Share on other sites More sharing options...
jplee123 Posted July 23, 2019 Author Share Posted July 23, 2019 1 hour ago, solver said: 2:12 is really shallow and you will have difficulty finding roofing materials to work on such a low slope. This shows the roof at a more practical 5.125:12 so it matches the main ridge. Thank you Eric. That's a great idea. Link to comment Share on other sites More sharing options...
jplee123 Posted July 23, 2019 Author Share Posted July 23, 2019 10 hours ago, DavidJPotter said: I programmed the attached, edited plan file so it can still be opened and worked in Architectural. DJP ArchitecturalPlan06b-2floor.zip Thank you David. I may consider buying or renting HD Pro. I appreciate all your help! Link to comment Share on other sites More sharing options...
