CCarpenter Posted June 6, 2019 Share Posted June 6, 2019 For this portico, how can I make 2 web components that start at the intersection of the kingpost and bottom chord and diagonally extend to the top chords at their mid-span? Thank you! HDPRO 2020 Link to comment Share on other sites More sharing options...
solver Posted June 6, 2019 Share Posted June 6, 2019 First project I did in Pro. Used standard roof truss. You can use a Custom Backsplash. Draw it against a wall, then move. If you want the wood grain correct, use multiple backsplashes -- one for each member and a material rotated to the correct angle. Link to comment Share on other sites More sharing options...
CCarpenter Posted June 6, 2019 Author Share Posted June 6, 2019 I was hoping to be able to actually build it our of lumber so it would register correctly in the materials list. I was steering away from a standard roof truss because I had other pieces that made it a little less "standard" but, maybe I'll give it a try. I tried making it with rafters but, the ends pointy and I can't find a way of specifying the angle. Thanks! Link to comment Share on other sites More sharing options...
solver Posted June 6, 2019 Share Posted June 6, 2019 On 6/6/2019 at 3:25 AM, CCarpenter said: I was hoping to be able to actually build it our of lumber so it would register correctly in the materials list. Expand Don't think there is a way -- not even in Chief. Link to comment Share on other sites More sharing options...
CCarpenter Posted June 6, 2019 Author Share Posted June 6, 2019 Bummer! OK, thanks for the info. Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 6, 2019 Share Posted June 6, 2019 an additional choice or choices: DJP Link to comment Share on other sites More sharing options...
