Shed Roof next to Gable Roof
krimco1
Hello!
In the 3D render attached the shed roof on the left with the skylight is correct. But the roof on the right over the garage is supposed to be a gable roof. I can't figure this one out. Blueprint view also attached. Thanks in advance!
The reason that part of the roof would not gable, is because you have two different ceiling heights. The Office and the Garage has
different ceiling heights, make them the same. Make the office side walls full gable and the front wall(s) high shed.
Also since you guys are familiar with my plan now I'll throw another problem I'm having at you. The roof line at the front of the house is off. The second floor extends out a bit and creates its' own roof line instead of extending the existing one. The attached pictures explain it pretty well. I can't figure out how to fix it. Any help would be greatly appreciated!
Thank you!
