RobynKS Posted November 17, 2014 Share Posted November 17, 2014 Thankyou for the answers I have had I am now able to put the type of post and beams I need into place. Next issue:- in the "Create A Custom Pergola Tutorial" it states that you can add millwork and corbels but it does not tell you how to attach then to the ends of your beams that you construct using soffits. The drawing shows them attached to rafters but not to beams. In the video it is for Chief Architect and we cannot do all of the necessary steps in Pro as we do not have the tools. Can anyone help? Please Link to comment Share on other sites More sharing options...
katalyst777 Posted November 17, 2014 Share Posted November 17, 2014 Your image makes it look like you already have it at the right height, so you just need to rotate the Corbel, and probably decrease its Width, which would be easiest to do in the Floor Plan view. Link to comment Share on other sites More sharing options...
RobynKS Posted November 17, 2014 Author Share Posted November 17, 2014 Thank you Leanne. But the corbel does not have a handle to rotate when I select it and I cannot work out how to rotate it. I am using Home Designer Pro. may Thanks Robyn Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 17, 2014 Share Posted November 17, 2014 It does have a "rotate handel", it is triagle shaped, look for it when it is selected. All such objects have triangular-rotate handels when selected DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted November 18, 2014 Share Posted November 18, 2014 are you sure it is a Corbel you are using? cos they should have a normal rotate handle as David mentioned like these zoom in if needed to see Link to comment Share on other sites More sharing options...
RobynKS Posted November 19, 2014 Author Share Posted November 19, 2014 As I am unable to add photos here to my answer/questions I have opened a new post. Many thanks for your answers I have worked it out now. see post Corbels. Link to comment Share on other sites More sharing options...
RobynKS Posted November 26, 2014 Author Share Posted November 26, 2014 All sorted many thanks everyone. Link to comment Share on other sites More sharing options...
