447Debbie Posted April 14, 2019 Share Posted April 14, 2019 See the orange part on the attached drawing. The ceiling over the deck is parallel to the roof's slope. I would rather have a soffit put in that joins up with the outside wall just below that orange section so that the ceiling of the deck is parallel to the deck's floor. What settings control this? Link to comment Share on other sites More sharing options...
solver Posted April 14, 2019 Share Posted April 14, 2019 Ceiling Over This Room Link to comment Share on other sites More sharing options...
447Debbie Posted April 15, 2019 Author Share Posted April 15, 2019 Eric, That added some other weird stuff. See the orange area at the top. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 15, 2019 Share Posted April 15, 2019 That "Weird Stuff" is called "a ceiling" that is set slightly lower than the roof. It is likely that there are other "settings" elsewhere that are incorrect for what you are trying to do. If you were to share a copy of your (.plan) file, others could then look and report back what was found. DJP Link to comment Share on other sites More sharing options...
solver Posted April 15, 2019 Share Posted April 15, 2019 On 4/15/2019 at 9:59 PM, 447Debbie said: That added some other weird stuff. Expand That's an auto generated attic wall that spans from the ceiling to the roof. What were you expecting? Raise the deck room ceiling to make it go away. Link to comment Share on other sites More sharing options...
