Soffit over deck
447Debbie
See the orange part on the attached drawing.  The ceiling over the deck is parallel to the roof's slope.  I would rather have a soffit put in that joins up with the outside wall just below that orange section so that the ceiling of the deck is parallel to the deck's floor.  What settings control this?
That "Weird Stuff" is called "a ceiling" that is set slightly lower than the roof. It is likely that there are other "settings" elsewhere that are incorrect for what you are trying to do. If you were to share a copy of your (.plan) file, others could then look and report back what was found.
1 hour ago, 447Debbie said:
That added some other weird stuff.
That's an auto generated attic wall that spans from the ceiling to the roof.
What were you expecting? Raise the deck room ceiling to make it go away.
