Odd Wall Issue
Muttley000
Possibly the roof on the right is overlapping the siding and cutting it back to the sheathing. Manually adjust the roof so it's just touching the siding.Or change the wall type of that wall if they are not to line up at the ridge.
Try to get the structure as you want before working on the roof. With auto roofs you can spend lots of time correcting the roof after a change in the structure, only to find your fix breaks after the next structure change.
I took a quick look at your plan and noticed some floor to floor wall alignment issues. These will be obvious in vector view. Selecting a wall that is misaligned, you will see an icon in the Edit Toolbar to automatically align with the wall above or below.
