RobynKS Posted November 1, 2014 Share Posted November 1, 2014 Hi All, I am trying to find answers in the reference manual pertaining to "siding" what do the items for each line mean as per photo 1. What is a siding 6 wall made up of? Is the blue section in my second photo? concrete? concrete block? or timber? Note the 1st photo is in imperial as it is of the video I am watching the second photo is in metric as it is of my actual plan in metric. I hope that is not confusing. Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 1, 2014 Share Posted November 1, 2014 The Reference Manual in this case and in my opinion is unnecessary. If you select each layer in the Wall Specicicatioin Dialog, one at a time that layers material will be displayedin the upper right-hand "Select Material" part of the dialog. Each wall layer can be adjusted as to its width value and its material assignment changed, all in this dialog. Where you have an arrow with a question markis not a layer at all but rather a line dividing the outter layer from the next layer inboard. You can see that the dialog box for "Siding 6" contains 5 layers (siding then moisture wrap, then sheathing, then framing and lastly interior sheetrock or drywall. (all shown in image #1) In the dialog image for "thick siding" there are only four layers If you actually confront those dialogs, they by themselves, tell you what is what. DJP Link to comment Share on other sites More sharing options...
katalyst777 Posted November 3, 2014 Share Posted November 3, 2014 In short, just activate the Thickness field for each layer, and you can see what it's made up of. 1 Link to comment Share on other sites More sharing options...
