BrianSS Posted December 10, 2018 Share Posted December 10, 2018 I am trying to create a single wall with multiple heights and angles. Is this possible? If so, how would I accomplish this? Thank you! Link to comment Share on other sites More sharing options...
LawB10 Posted December 10, 2018 Share Posted December 10, 2018 Use room dividers to create rooms, then lower the ceiling heights. Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 10, 2018 Share Posted December 10, 2018 Only if you have Home Designer Pro can you accomplish this using a wall object. Varying right-angle heights can be emulated using a series of soffits or geometric shapes in any Home Designer Title. Like others have said, your question is so general and open to interpretation that we can only guess as to what, exactly you want to do. DJP Link to comment Share on other sites More sharing options...
BrianSS Posted December 11, 2018 Author Share Posted December 11, 2018 I'm sorry y'all. My question was pretty vague. I'm going to be converting an existing barn into a living space. The roof is a barn style which has 2 different pitches on both sides. It also will have a partially vaulted living room with a 3' tall dormer that will be flush with an exterior wall. I'm having trouble with creating those two things. I hope that explains it better. I tried uploading a couple pictures but they're too big. Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 12, 2018 Share Posted December 12, 2018 How to set up and create a barn roof is described in "Roof Styles - Barn Roof" in the "Build Roof Dialog" in your software. To then obtain a dormer in such a roof is rather difficult using the "Dormer Tool" due to 3D Geometry limitations of that tool (a dormer must fit within a single roof plane area, it cannot cross the edge of its parent roof plane which makes it difficult to adjust "Dormer Defaults" so that one can easily be created in such a roof system. For Barn roof dormers I commonly create them manually after carefully laying them out in plan view first. DJP Link to comment Share on other sites More sharing options...
BrianSS Posted December 13, 2018 Author Share Posted December 13, 2018 Thank you very much David! Link to comment Share on other sites More sharing options...
