dylantuttle2015 Posted November 14, 2018 Share Posted November 14, 2018 Hi guys! I've had great success in asking questions here before. I've had good luck in creating spaces as well. My self and my interior designer have been collaborating in making new plans. The newest problem is we get an error message saying "The extents of the view being generated are unusually large. This may be cause by an object that is very far away from the origin." I'm assuming this resulted from something that was put in the plan but I can't find it. I attached a screenshot of the error message and a copy of the plan below. What could cause this? Steinkamp Basement.plan Link to comment Share on other sites More sharing options...
solver Posted November 14, 2018 Share Posted November 14, 2018 Do a Fill Window (F6). The plan will show really small. Zoom out some more, then marquee the entire bottom of the screen. Delete. You may need to do this a couple of times. Do a Fill Window Building Only, then a Fill Window. They should be about the same. If not repeat the above. Link to comment Share on other sites More sharing options...
Jo_Ann Posted November 14, 2018 Share Posted November 14, 2018 Whatever you misplaced in outer Mongolia, I couldn't find. Your 2d plan is also not centered on the xy center of the screen. To save yourself from ripping out hair, try this: Open a new plan and tile vertically beside original plan. Choose (tool bar) EDIT/ edit area, and marquee around the entire existing plan, and (tool bar) COPY. Reselect the NEW plan, (tool bar) PASTE, then center your curser between the side slider and lower slider bar (aka center of the screen), and Paste. All should be better now. Do a 'save as' (choose same name as old plan) and new plan is saved, and old plan is deleted. DONE. Link to comment Share on other sites More sharing options...
dylantuttle2015 Posted November 21, 2018 Author Share Posted November 21, 2018 Thank you guys so much! That was just the help I needed and it worked out great for me. Thanks again! Link to comment Share on other sites More sharing options...
