Sign in to follow this
Rondavis
Rondavis
How can I make a vertical framed wall from a wall in the floor plan? The program is home architect pro 2019.
Welcome to the forum. There is no such software with the name "Home Architect Pro". Do you have Home Designer Pro 2018? or do you have Home Designer Architectural 2018? it is one or the other.
I do not understand your question no matter what software you have, I mean you select the "Wall Tool" and then select what kind of wall type you intend to draw and then left-click-drag to create the selected wall type. If you mean something else, then please say more to explain.
You're correct, it's home designer pro. I'll try what you say and respond after.  Thank you for the welcome.
I have a floor plan, I want to create a plan for each wall showing the studs, headers, ect. from the walls on the floor plan. Do I have to draw each wall based on the dimensions on the floor plan or is there an easier way that I'm not seeing? I've tried for about 8 hrs. and not getting it.
Yes
