arc ceiling at entryway
keendevelopments
Create a custom object in Sketch Up and then import into Home Designer is all I can think of. This can be done easily within Chief Premier but that is another story. The free version of Sketch Up will do the job, it is free and easy to learn.
thanks so much guys, so glad to have that figured out. ill post the new design with the arc entryway..
i have a question for you Eric. the next thing ill be working on is the siding detail. would you recommend using that same custom backslash tool to achieve the higher hardy panel? please refer to the original photo i posted.
i found corner trim but cant seem to find any tool for other exterior trim. would soffit tool be the right tool to use for the other trim and battons?
thanks again i really appreciate the help
You could use the backsplash tool for the light gray siding and the trim. I would make a new wall type with that type of siding and fill in where it does not work.
 A soffit would also work for the trim where it's not curved.
