rosiebeauginger Posted February 1, 2018 Share Posted February 1, 2018 I have created 2nd floor parapet walls following the instruction in user support. The parapet wall is not aligning correctly with the 1st floor (see photo). I have verified that both the first floor wall and the parapet half wall are set to the same width of 6". I have also clicked the icon to align the parapet wall with the wall below. I tried randomly changing the width of the parapet wall to 10" and this had no effect on the visual appearance so width does not seem to be the issue. What else should I check to correct the alignment? Thank you. Software version: Home Designer Pro 2018 Link to comment Share on other sites More sharing options...
solver Posted February 1, 2018 Share Posted February 1, 2018 To automatically align, the walls need to be defined the same, not just be the same thickness. Alignment is done to the main layer outside, so make the parapet wall match the lower wall and it should work. For many questions like this, posting a simple plan demonstrating the problem would be helpful. Here just copying 2 walls and placing them into a second plan would be ideal. Link to comment Share on other sites More sharing options...
rosiebeauginger Posted February 1, 2018 Author Share Posted February 1, 2018 You are correct, wall type was the culprit. Thank you kindly for your assistance. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 1, 2018 Share Posted February 1, 2018 Be sure that your parapet wall is the same wall type as other exterior walls. That being the case, they then should line up, floor to floor. DJP Link to comment Share on other sites More sharing options...
