ICONDEV Posted November 11, 2017 Share Posted November 11, 2017 I know Architectural handles showers, but what's the best way to do a corner shower in Suite? I've built normal walls, and installed a hinged glass door, but It's running my walls all the way up to the vaulted ceiling above. I just want to cut it off at 10' and leave open. Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 11, 2017 Share Posted November 11, 2017 Since you cannot manually resize wall poly-lines like you can in Pro, In Architectural, Suite, and Essentials you have to use objects to represent glass walls that you can control their height. My choice would be soffits found in "cabinet tools", you set it to emulate glass and can easily control its height. You section the corner shower from the bathroom using invisible walls and you turn off the moldings in the shower room. DJP 1 Link to comment Share on other sites More sharing options...
LawB10 Posted November 12, 2017 Share Posted November 12, 2017 Use half walls and set the height to 120" then click>rail style>panels, check post to rail and uncheck raise bottom rail/panel. Click Materials>Panel and change it to glass. 1 Link to comment Share on other sites More sharing options...
ICONDEV Posted November 12, 2017 Author Share Posted November 12, 2017 Thanks fellas, I've since upgraded to Architect, so is there any easier way now? Link to comment Share on other sites More sharing options...
ICONDEV Posted November 13, 2017 Author Share Posted November 13, 2017 watching the video now! Link to comment Share on other sites More sharing options...
