designer468 Posted October 31, 2017 Share Posted October 31, 2017 I am getting a weird bump in my interior wall where the attic wall and room wall meet. I went into the attic and made sure the walls were the same length. I've tried to align them, but the Align with Wall Below feature is never given to me. I've searched high and low. When I click or right click on the attic wall, it does not give me the option to align it with the wall below. So I've visually aligned them. Everything appears to meet, but in Camera View ... I continue to get the bump in the wall. 468 Baltusrol Remodel-2 Pro Auto.plan Link to comment Share on other sites More sharing options...
solver Posted October 31, 2017 Share Posted October 31, 2017 Try making the lower wall Balloon Through Ceiling Above. You may then delete the upper (attic) wall if the program does not. Link to comment Share on other sites More sharing options...
designer468 Posted October 31, 2017 Author Share Posted October 31, 2017 That worked! I had to manually delete the upper attic wall. Once I did that, the Balloon feature on the wall below worked perfectly. That's a great feature to know. Thank you! Link to comment Share on other sites More sharing options...
LawB10 Posted November 1, 2017 Share Posted November 1, 2017 Just out curiosity, why did you delete the second floor? Link to comment Share on other sites More sharing options...
designer468 Posted November 2, 2017 Author Share Posted November 2, 2017 I don't think I deleted the second floor. I can still see it when I go up levels. The second floor is Open Below to give the vaulted ceiling effect. Link to comment Share on other sites More sharing options...
