rvbinder Posted August 21, 2017 Share Posted August 21, 2017 A "reagent shelf" provides a raised ledge over a base cabinet to put stuff - very handy and looks cool. I tried drawing this as a soffit, a railing, and a custom wall type, but none of that worked. Here's a side view of what I'm trying to do. How can I draw a reagent shelf on top of a base cabinet? Link to comment Share on other sites More sharing options...
Rookie65 Posted August 21, 2017 Share Posted August 21, 2017 Hi Bob, Maybe try it as a custom countertop? Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 21, 2017 Share Posted August 21, 2017 1 Link to comment Share on other sites More sharing options...
rvbinder Posted August 21, 2017 Author Share Posted August 21, 2017 That does it ! Thanks. Link to comment Share on other sites More sharing options...
rvbinder Posted August 21, 2017 Author Share Posted August 21, 2017 A few additional notes: Made slab height same as supporting structure. This room for this was on the 2nd floor, so I had to use absolute heights for the slab bottom and top, per room structure panel. Made slab flush to wall. Made the slab same dimensions as the supporting structure for the shelf, then backed the cabinet up to that. Used the cabinet backsplash, changed the thickness and height. Added a custom countertop for the shelf piece Elevation attached. Done for now -- going outside to get eclipsed. Link to comment Share on other sites More sharing options...
