crosscutter55 Posted June 20, 2017 Share Posted June 20, 2017 I would like to show a detail of stringer cut outs . i cant get the program to show the proper angle which is 32.47 degrees . Then the degree that shows up also says degree & feet also would love to make a thin 1/16 polyline so i can fix the woodgrain . Any help is always appreciated Link to comment Share on other sites More sharing options...
solver Posted June 20, 2017 Share Posted June 20, 2017 Draw it with CAD lines. Link to comment Share on other sites More sharing options...
crosscutter55 Posted June 21, 2017 Author Share Posted June 21, 2017 After it is made using cad lines what is the best polyline to use / countertop / slab ?? I also want to see this the same way as if it was in a cross section is there a way to rotate this view ? Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 21, 2017 Share Posted June 21, 2017 "Best" is an opinion, what i usually use is custom slabs though there is no real difference between a custom counter top and a custom slab. CAD objects are by default 2D, whereas 2D CAD objects converted to 3D objects can then be viewed from any angle, so what you use should depend upon what the purpose of the object is. DJP Link to comment Share on other sites More sharing options...
