Douglas49 Posted June 6, 2017 Share Posted June 6, 2017 The window in this plan has been made up of five windows sized and grouped together. On the interior side, the casings go around each of the five windows, which is not how it is in real life. Have I done this correctly? If I upgraded to Chief Premier, would this problem be sorted? Regards window group.plan Link to comment Share on other sites More sharing options...
solver Posted June 6, 2017 Share Posted June 6, 2017 9 hours ago, Douglas49 said: On the interior side, the casings go around each of the five windows, which is not how it is in real life. How is it supposed to look? Telling us what's wrong is important, but we need to understand what is correct too. Posting the plan is good too, but an image or 2 helps as well. Here I've turned off all casings, and used the Custom Backsplash tool to draw in the casing, guessing that this is the look you want. Link to comment Share on other sites More sharing options...
LawB10 Posted June 6, 2017 Share Posted June 6, 2017 Upgrading to Premier would be overkill for what you want do. Delete the bottom windows and resize, then make the side windows double awning and resize the bottom components. Uncheck casings for all windows and it will look like solver's image. Link to comment Share on other sites More sharing options...
Douglas49 Posted June 6, 2017 Author Share Posted June 6, 2017 Thanks LawB10 - I don't know how I missed the setting to resize the bottom component - I was sure it would be there and looked for it several times. But all good now. Thanks also for the upgrading comment. Link to comment Share on other sites More sharing options...
