PLANsLLC123 Posted May 29, 2017 Share Posted May 29, 2017 Greeting, This plan has had various things come up that I have had to become familiar with and appreciate the help along the way. One last question, hopefully, concerns problems I am having with the walls below dormers not connecting. My first issue was knowing I needed 2 x 6 walls under vs. 2 x 4, then aligning as closely as possible for Connect Wall function to work. But, I am still having issues along one side of the building and don't know how to resolve. If someone could point me in the right direction, it would be appreciated. Thank you, Tim Floor Plan; Design _4 (HDP)(COPY).plan Floor Plan; Design _4 (HDP)(COPY).zip Link to comment Share on other sites More sharing options...
solver Posted May 29, 2017 Share Posted May 29, 2017 Something wrong with your attachments. Make sure the plan is not open in Pro. Link to comment Share on other sites More sharing options...
PLANsLLC123 Posted May 29, 2017 Author Share Posted May 29, 2017 The plan is now closed, thanks. Link to comment Share on other sites More sharing options...
solver Posted May 29, 2017 Share Posted May 29, 2017 I needs to be closed when you upload and/or zip it. You will need to do the upload again with the plan closed. Link to comment Share on other sites More sharing options...
PLANsLLC123 Posted May 29, 2017 Author Share Posted May 29, 2017 Hopefully this will get it. Floor Plan; Design _4 (HDP)(COPY).zip Link to comment Share on other sites More sharing options...
solver Posted May 29, 2017 Share Posted May 29, 2017 Nope Link to comment Share on other sites More sharing options...
PLANsLLC123 Posted May 29, 2017 Author Share Posted May 29, 2017 Alright...one more time...plan is not open, it is being attached after the plan is closed...this is also the drawing in .plan format...not zipped. thanks for your patience. Tim Floor_Plan;_Design__4_(HDP).plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 29, 2017 Share Posted May 29, 2017 Here is my advice on this subject: a way I have developed to deal with this type of wall conflict Floor_Plan;_Design__4_(HDP).zip Link to comment Share on other sites More sharing options...
solver Posted May 29, 2017 Share Posted May 29, 2017 On 5/29/2017 at 4:28 PM, PLANsLLC123 said: I am having with the walls below dormers not connecting. Expand I see you have 5 dormers, but only one showing. Not sure what connecting problems you are having. Link to comment Share on other sites More sharing options...
PLANsLLC123 Posted May 29, 2017 Author Share Posted May 29, 2017 Thank you for your help Eric and David. The video was VERY helpful....problem solved! Next challenge is the gable end exposed timbers.... Much appreciated. Link to comment Share on other sites More sharing options...
