Patio - curved angle not tight enough
matt36
I have Home Designer Architectural and I am trying to draw a patio out for my backyard.  Part of the patio is curved and will have a fire pit in the middle of it.  I am using a curved railing object but I cannot get the arc to be tight enough given the space.  What is the recommended method of accomplishing this?  I want an curve more like the top of the pink circle in attached picture.  There is probably an easy solution to this but I am just not seeing it.  Thanks!
Actually there is not an "easy solution" but there are things you can do to make this easier. Temporarily turn off "Angle Snaps" just until you get exactly what you want. This action makes drawing arc's and circles a bit easier also using the "Alt" key while editing an arc of either a curved wall or a CAD arc. Is the patio area a circle like your pink circle? If it is an area within a larger area as looks the case above from your image, I would use invisible walls especially if the floor material differs from the larger area's floor area. This is a trail and error action, just keep trying until you do get the look you want. It can be done.
David, That helped tremendously turning off the "angle snaps".  I think I should be able to make it happen now.
Thank you for the help!
-Matt
1) Please fill out your Signature -- see below.
2) I'm curious why you are using a curved railing. Do you need the railing, or a roof over the patio?
It helps if we know what title (Suite, Pro etc) and version (2014, 2015 etc) you are using. You can add this info to your signature by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left. Doing so makes it always available, and this info is often key to providing a good suggestion
Resources for self help:
Re: #2 I am using a railing as I need sitting walls on the patio.  Specifically around the fire pit.  Additionally, that is what was suggested in this knowledge base article that I was following.  https://www.homedesignersoftware.com/support/article/KB-00910/modeling-a-brick-patio.html . If there is a better was to model this please let me know.
Thanks!
-Matt
You might try using 2 slabs for seating benches (1 for the base, 2nd for the cap).
Manipulate the height, width, and curve to get exactly what you want.
Then hold down control key, and select both slabs/copy/paste, and you will have 2 benches that are identical.
