Home Designer Architectural Roof Question
Bcavender
In HDA2017 I have constructed three separate buildings on terrain. One is currently in place and has a metal roof which is different from the other two planned buildings.
I have tried selecting just a single structure and then adjust the roof materials to match the existing structure.  However, when I do this, it also sets the other two unselected structures to the same roof material.
The HDA 2017 Reference Manual doesn't appear to show any way (that I could see) to set different roof materials on separate structures.
Am I missing something simple here or might this be a limitation of HDA2017?
Best regards,
Bruce
Law,
Thanks for the response.
That is one of the permutations I had tried.  I double checked that "AutoRebuild" was off and tried it again with the same results.
Maybe I am missing something else?
Maybe HD Architectural package doesn't allow this?   An odd problem.
Thanks!
Bruce
OK, figured it out.
Definitely Auto Rebuild must be off/stay off.
For the second roof, don't use the Build =>Roof command to spec roof material.
Just use the spray can tool to add the different bit map on top of the other structure.  Easy ...
Thanks!
Bruce
