guy8121 Posted February 7, 2017 Share Posted February 7, 2017 Hi everyone. Ive created 2 different buildings on the same file so i can view them how they will be positioned on my property. One is a house and the other is a steel building. Selecting diiferent exterior wall materials was easy enough but i cant figure out how to use different roof material for each building. I want to use shingles on the house and metal roof on the steel building. Any suggestions? Link to comment Share on other sites More sharing options...
solver Posted February 8, 2017 Share Posted February 8, 2017 Pick your material, apply it to the roof. Link to comment Share on other sites More sharing options...
guy8121 Posted February 8, 2017 Author Share Posted February 8, 2017 Im sure im missing something simple but everytime I try to change the roof material for the steel building it also changes the roof material on the house Link to comment Share on other sites More sharing options...
solver Posted February 8, 2017 Share Posted February 8, 2017 Make sure the Painter Component Mode is correct. Should be Component. Link to comment Share on other sites More sharing options...
guy8121 Posted February 8, 2017 Author Share Posted February 8, 2017 The painter mode selected is component and it still changes both roofs. Is there anyway to separate the buildings and keep them on the same file? Link to comment Share on other sites More sharing options...
solver Posted February 8, 2017 Share Posted February 8, 2017 I checked in a copy of Suite which I believe has the same roof options as Architectural. Could not get different materials on 2 buildings. This has been discussed on the forum sometime in the past, so searching may find a better answer. No way to separate buildings. Pro, with its advanced roof tools can do this. Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 8, 2017 Share Posted February 8, 2017 Turn off 'auto rebuild roof', THEN use the paint can. 1 Link to comment Share on other sites More sharing options...
katalyst777 Posted February 8, 2017 Share Posted February 8, 2017 Jo_Ann's got it. Turn off Auto Rebuild Roofs first. Then use the Material Painter spray can while in Component Mode. 1 Link to comment Share on other sites More sharing options...
guy8121 Posted February 8, 2017 Author Share Posted February 8, 2017 Thank you! That worked! Link to comment Share on other sites More sharing options...
