8Mango Posted January 25, 2017 Share Posted January 25, 2017 Beginning with HD Pro on a Mac, I have drawn my first plan exterior walls. Now I want to go back and cut out sections of the exterior and insert sections of different walls. (My plan models an existing house which has been heavily remodeled.) I've seen how to insert wall breaks, and I experimented on a separate plan by drawing a long wall, breaking a middle section of its length, and deleting that section. But I've been unable to insert or attach a new wall type between the two ends where I cut a section out of the wall. Attached is my wall experiment. I drew a long, straight wall, then cut out a center section of it. Now I want to fill that blank space with a different type of wall. Thanks in advance. Wall Test.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 25, 2017 Share Posted January 25, 2017 You simply draw the wall type of your choice. The way I would do it is make my wall breaks and then open the Wall dialog box of the center segment of the wall, open its dialog, select the "Wall Types" tab and select a different wall type for the segment. Ideally the new wall type should be the same thickness as the original long segment for structural purposes. DJP Link to comment Share on other sites More sharing options...
8Mango Posted January 25, 2017 Author Share Posted January 25, 2017 (edited) Thanks David. For some reason I can't fathom "drawing the wall type of your choice" isn't happening for me. Should I have not deleted the selected section before I tried to draw a new wall? For some reason I can't even get the test sample I attached to my message to even draw any kind of wall where the deleted original section was. For instance, I went back to my Wall Test attached to my original message, I chose the "Build" menu / Straight Exterior Wall / Define Wall Types, and clicked "OK" on a different wall type I had already created--an 11" thick brick & block wall. Then I tried to draw that wall between the two ends of the wall in my test plan. But all I got was a dashed line, not a wall. See my result at this second attachment Wall Test2 Wall Test2.plan Edited January 25, 2017 by 8Mango Added more information and an attachment Link to comment Share on other sites More sharing options...
8Mango Posted January 25, 2017 Author Share Posted January 25, 2017 Signature info added. Thanks for that tip. But I wonder why yours drew a wall and mine didn't? I'll continue to research. Link to comment Share on other sites More sharing options...
solver Posted January 25, 2017 Share Posted January 25, 2017 Did you try replacing the wall as David suggested? Double click (or whatever you do on a Mac) on the section you want to change. Go to Wall Types, pick a unique one and see if it changes. Link to comment Share on other sites More sharing options...
8Mango Posted January 26, 2017 Author Share Posted January 26, 2017 I figured it out, but it was a long process. I got help from C.A. staff, but I still had to stumble around and find some things for myself. Here is what I eventually found to work: Build Menu>Wall>Break Wall to choose limits of wall area to change. Then go to Edit MENU>Select Objects>to select this desired wall section between the inserted breaks. After selecting object, the Edit TOOL PANE (not drop down menu) will appear. Use Open Object tool, a Wall Specification dialog will open. Scroll down list on left side of the dialog to “Wall Types.” A drop down menu line will appear within the Wall Spec dialog. Use it to choose the type of wall to replace the selected section with. Select OK and the new wall type will be inserted. Previously I had been trying to use Build>Wall>Define Wall Types to start drawing a new wall in the old section area. It didn't work, and I didn't need to draw a new one, just change the area I selected with the process above. Thanks (and my signature should show up now with my system info, too) Link to comment Share on other sites More sharing options...
