rfcomm2k Posted September 20, 2016 Share Posted September 20, 2016 In the attached plan the first floor kitchen pantry has double doors. When I show a wall elevation, it indicates the floor molding does not end at the edge of the door frame like it should. The molding does end where it should on single doors (look at elevation of the door from kitchen into the garage for example). I do not see any settings I can change for this. block diagram 4A3a floorplan with framing.plan Link to comment Share on other sites More sharing options...
katalyst777 Posted September 20, 2016 Share Posted September 20, 2016 I was thinking maybe the door was raised up from the floor or something, but it looks fine to me? Link to comment Share on other sites More sharing options...
rfcomm2k Posted September 20, 2016 Author Share Posted September 20, 2016 Well it looks bad on my PC. Link to comment Share on other sites More sharing options...
Solution solver Posted September 20, 2016 Solution Share Posted September 20, 2016 Please post a picture of what you are seeing. Like Kat, I see no problem. I do wonder why the doors have no casing. Link to comment Share on other sites More sharing options...
rfcomm2k Posted September 20, 2016 Author Share Posted September 20, 2016 Ur funny Eric. I had "Suppress Interior Casing" checked on the door DBX. That cured the molding problem, but I still see no casing around the door. Link to comment Share on other sites More sharing options...
solver Posted September 20, 2016 Share Posted September 20, 2016 Did you have a reason for setting the casing default width to 0"? Link to comment Share on other sites More sharing options...
LawB10 Posted September 20, 2016 Share Posted September 20, 2016 Did you have a reason for setting the casing default width to 0"? LOL Link to comment Share on other sites More sharing options...
rfcomm2k Posted September 22, 2016 Author Share Posted September 22, 2016 I thought that casing default indicated how many cases of beer it would take to build this. My bad. Link to comment Share on other sites More sharing options...
