Octagonal or Round Windows
MauiMike
From the library catalog click  Architectural>Windows
Thanks! But now that you pointed me to the right place, I'm having the following problem: I put in an octagonal window, which defaults to 36" x 36". But as soon as I change anything about its properties (dimensions, casing size, etc.), the window turns into a square! Any ideas?
I was able to do a round window (see picture), but not an octagonal one.
For some reason Suite won't allow you to resize some doors and windows.
The Octagonal window comes in 2 sizes 24" and 36", as have you seen, it won't allow you to resize it.
The workaround is to use the pass thru tool and then add 2 wedges and 2 inverted wedges, resize to your liking.
I like your idea ... but I'm not finding in 3dwarehouse a wedge that would give me the 3 sides of the octagon. Can you direct me to such a shape? Thanks!
