Chiefuser_BL Posted July 7, 2016 Share Posted July 7, 2016 Is there a simple way to select an object or preferably objects and make them "Invisible" like in the wall options? I simply want to take them out of the picture in 3D view so that I can see other objects in the room. Link to comment Share on other sites More sharing options...
LawB10 Posted July 7, 2016 Share Posted July 7, 2016 Either move them out of way or delete them. You can't make object(s) invisible. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 8, 2016 Share Posted July 8, 2016 In Home Designer titles and versions LawB's answer is correct, In Chief Architect Premier one can set images and objects on any layer or custom made layers and then turn them on or off at need but as I said, this is only possible in Premier. DJP Link to comment Share on other sites More sharing options...
katalyst777 Posted July 11, 2016 Share Posted July 11, 2016 You COULD change all their materials to "Opening-No Material" so you don't see them in 3D, but it would be a lot of extra work to get the material's back.But, it would be easier to make a copy of the plan with the objects moved/deleted using Save As. That way you can return to the original file where they are still present. As David suggested, the Premier version has easy tools to do what you want, but you can work around the Home Designer limit. Link to comment Share on other sites More sharing options...
