Sign in to follow this
Gothic
Round windows become square windows
I want to place a round window onto a wall and increase the size.  As I expand the dimensions the round window eventually becomes a square window.  Is the any way I can make this window larger and still maintain the correct shape of the window ?  The same also happens for oval windows.
What version?  Was window made round using the arch settings, or placed from browser?
I'm using Home Designer Architectural 2017 with latest update.  The window was placed from the library,  i.e.,  Architectural/windows/round.  If you can instruct me how to do this using arch settings I would appreciate it.  Thanks much.....
Delete the "round window" and replace it with a default window which you can then control by way of its dialog box. The specialty windows from the Library Browser can be resized but not otherwise changed as to their character.
I don't think Architectural has the ability to create these shaped windows directly like Pro can, so you're probably limited to the ones from the Library Browser and their sizes.
