behlingw Posted June 27, 2016 Share Posted June 27, 2016 I just purchased the 2017 version of Home Designer. When downloading from the online 3D library, would I only download the 2017 files? For example, the Rec Room and Games 3D models has a few versions. Would I get everything from that category if I only download the 2017 files? Or would I need to download all of the previous versions as well? Also, are the previous versions compatible with the 2017 software? Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 27, 2016 Share Posted June 27, 2016 You should be able to download older libraries, try and see. Older plan files can be opened in newer versions but older versions cannot open and edit newer version plan files, that is the way it has always been. DJP Link to comment Share on other sites More sharing options...
Solution LawB10 Posted June 27, 2016 Solution Share Posted June 27, 2016 The latest version has all files of the older versions plus some, the older files are for the older versions of the software. For 2017, the version is X8 that's the one you download. No need to download the others, you will have duplicate materials, objects and fixtures if you do. Link to comment Share on other sites More sharing options...
