Sign in to follow this
behlingw
Question about 3D Library
I just purchased the 2017 version of Home Designer.  When downloading from the online 3D library, would I only download the 2017 files?  For example, the Rec Room and Games 3D models has a few versions.  Would I get everything from that category if I only download the 2017 files?  Or would I need to download all of the previous versions as well?
Also, are the previous versions compatible with the 2017 software?
You should be able to download older libraries, try and see. Older plan files can be opened in newer versions but older versions cannot open and edit newer version plan files, that is the way it has always been.
 The latest version has all files of the older versions plus some, the older files are for the older versions of the software.
For 2017, the version is X8 that's the one you download. No need to download the others, you will have duplicate materials, objects and fixtures if you do.
