Vikki_WA Posted May 5, 2016 Share Posted May 5, 2016 In a 3D view I can select a wall and get edit handles on all sides so that I can change the top and bottom heights of the wall, but this doesn't seem to be available with railings (no top or bottom handles). The default top and bottom height are greyed out in the dialog box as well. I want to lower the bottom of a fence to drag it below the terrain ("bury" the bottom). Any idea how to do this? Link to comment Share on other sites More sharing options...
solver Posted May 5, 2016 Share Posted May 5, 2016 Why do you want to bury part of it? If you create a room -- one wall is the fence, the other 3 are room dividers, you can lower the floor which will do what you want. Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted May 5, 2016 Solution Share Posted May 5, 2016 Railing walls have a dialog box for their editing, unlike other walls that also have edit handles as you have observed. DJP Link to comment Share on other sites More sharing options...
