1ucieAlfie Posted April 24, 2016 Share Posted April 24, 2016 I am trying to create an indoor corridor with an arched ceiling. This will not follow the roof line. Can this be done in Home Designer Suite 2015 ? Is it possible in any other package, if so which one/s ? Any advice would be gratefully received. Many thanks for taking the time to read this. Link to comment Share on other sites More sharing options...
scottharris Posted April 24, 2016 Share Posted April 24, 2016 You probably need Chief Architect Premier for a curved or barrel ceiling; it can be rented for $199/mo. Link to comment Share on other sites More sharing options...
Elovia Posted April 24, 2016 Share Posted April 24, 2016 Barring the suggestion by scottharris, you can create an arched ceiling shape in SketchUp and then import it into your hallway; this is likely to be a rectangular block with a concave curved surface on the underside.. This is probably the easiest (or only) way for HDSuite. Alternatively, with significantly more work, you can create a barrel ceiling in HDPro using many ceiling planes similar to the following knowledge base article, but using ceiling planes instead of roof planes: https://www.homedesignersoftware.com/support/article/KB-01187/creating-a-barrel-roof.html Good luck. Link to comment Share on other sites More sharing options...
LawB10 Posted April 24, 2016 Share Posted April 24, 2016 Like Elovia said, you would have to create the ceiling using a Arc or go to 3d warehouse and search for Barrel Ceiling. I have the file but cannot upload, the forum doesn't allow it. Link to comment Share on other sites More sharing options...
