Ron-Aus Posted April 14, 2016 Share Posted April 14, 2016 I am creating an alcove on an outside wall without a roof over. I want to create a roof plane from the rear wall of the alcove on the same plane as the adjacent roof planes. The opposite walls in the alcove will angle upwards. Can I do this in Ver 10 of Home Designer Pro? Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 14, 2016 Share Posted April 14, 2016 Can I do this in Ver 10 of Home Designer Pro? Yes you should be able to but like Eric said, we could all be more sure if we had a copy of your plan or at least some screen captures of this alcove you are asking about. DJP Link to comment Share on other sites More sharing options...
Ron-Aus Posted April 21, 2016 Author Share Posted April 21, 2016 Alcove.plan Drawings displayed with auto generated roof. I want to create roof as in second drawing without roof over alcove. Link to comment Share on other sites More sharing options...
solver Posted April 21, 2016 Share Posted April 21, 2016 I am creating an alcove on an outside wall without a roof over. I want to create a roof plane from the rear wall of the alcove on the same plane as the adjacent roof planes. The opposite walls in the alcove will angle upwards. Can I do this in Ver 10 of Home Designer Pro? Drawings displayed with auto generated roof. I want to create roof as in second drawing without roof over alcove. I'm confused about what you are trying to do. Your plan shows 2 structures, one has a roof over the alcove, one does not. Is this what you want? Does Pro 10 have manual roofs? Link to comment Share on other sites More sharing options...
Solution Ron-Aus Posted April 21, 2016 Author Solution Share Posted April 21, 2016 Thank you Eric. Your drawing of the roof is exactly what I want and Yes, HD Pro 10 has manual roof construction, and this works. Link to comment Share on other sites More sharing options...
