How do I remove extraneous parts from gable?
cte677
Go to solution Solved by DavidJPotter,
Can't find that dialog box.
Tried: Build -> Roof -> Build Roof -> ... no Framing Tab.
Then tried: select wall -> Open Object -> Roof ... no Framing Tab.
There are some "white" areas that are inexplicable to me ... see attachment ... marked with red circles.
  • Solution
Sorry, I was speaking in terms of having Home Designer Pro. In Architectural all you can do is to vary the value in the "Upper Pitch" until by trial and error find a value that works with the geometry of your model. Your current setting is the cause of the unwanted artifacts, so change it until they go away.
