43214321 Posted March 11, 2016 Share Posted March 11, 2016 How do I modify this base cabinet so that it does not stick out of the angled wall outside of the bathroom area ? I use Home Designer Pro 10 Link to comment Share on other sites More sharing options...
solver Posted March 11, 2016 Share Posted March 11, 2016 The program does not do cabinets with angled backs -- even the newest Chief Premier does not do this. You can set the depth of that cabinet so it does not extend through the wall. Link to comment Share on other sites More sharing options...
LawB10 Posted March 11, 2016 Share Posted March 11, 2016 Go to Cabinets>Accessible Cabinets>End Cabinet Base See if that works for you, also you may need to use a soffit as a filler. Link to comment Share on other sites More sharing options...
43214321 Posted March 11, 2016 Author Share Posted March 11, 2016 As Solver mentioned, I made the cabinet very shallow, removed its countertop and then made a custom countertop top to fit the angle, and it worked beautifully. Just passing along "the fix" . . . thanks for the suggestions ! Completed with Home Designer Pro 10 . . . 1 Link to comment Share on other sites More sharing options...
