ArchieD Posted February 19, 2016 Share Posted February 19, 2016 I'm having trouble figuring out how to change grout color. In the library the tile appears to have dark grout lines, but when I place it, it shows up bright white in 3D! Link to comment Share on other sites More sharing options...
solver Posted February 19, 2016 Share Posted February 19, 2016 You can edit the texture file in a program like Photoshop to change the grout, and change the pattern file with the adjust material definition tool. Link to comment Share on other sites More sharing options...
ArchieD Posted February 19, 2016 Author Share Posted February 19, 2016 OK, thank you---are you aware of a video out there showing those steps? I will give it a go..... Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 19, 2016 Share Posted February 19, 2016 I know of no videos on this subject but it involves 1. exporting the existing texture file as a copy. 2. Altering that texture file in an image editing application like Eric suggested. 3. Importing the edited texture as a new custom material (see Reference Manual for details). 4. As part of creating the new custom material you give the new material a new name and import it into your "Users Catalog" area of the Library Browser. The steps are not complicated but require preciseness. DJP Link to comment Share on other sites More sharing options...
ArchieD Posted February 19, 2016 Author Share Posted February 19, 2016 Thanks. In one of your youtube videos, David, you changed the line in the chip mosaic tile to black to allow it to print....it also showed up black. Were you able to get that because it was placed on a shower base and not floor? I could not get the same options you did using the "adjust material definition" tool. It looked so easy, but not so?? I will try my hand at your instructions, thought I am limited in my graphics programs....hopefully I can get something to happen in "Paint" (good thing I can't hear everyone chuckling right now) Link to comment Share on other sites More sharing options...
ArchieD Posted February 20, 2016 Author Share Posted February 20, 2016 .....or I could just find a tile with grout I like and change the tile color to replicate the one I like. Funny I didn't think of that before.... Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 20, 2016 Share Posted February 20, 2016 Commonly you open the dialog box of the object you want to change. Then go to its "Material Tab". Select the material you wish to alter as a "Plan Material" where you can then select its Dialog box to change its vector lines to black for black and white vector view printing. Without handling the original Material Texture that change does not, by itself effect Render view camera appearances. DJP Link to comment Share on other sites More sharing options...
