OddBall1958 Posted February 10, 2016 Share Posted February 10, 2016 Since I'm a NU-BEE I'm going to be asking a lot of questions. First off! I'm using Home Designer Architechtural 2016. So far I've had some great help in the forums with my issues and learning experience. Thanks for your patience and the help. So here is my dilema! I've been working on the attached plan and has been going along just fine until now. I'm trying to add a shed roof on the second floor where a Master Bath and Closets will be. I've tried following the shed roof tutorials with difficulties. The problem I'm running into is that every time I try these actions the whole roof line changes. How can I accomplish this feat? What am I doing wrong? Looking at the second floor plan this shed roof would be in the upper right corner from the north outer wall to the stairwell and from the right exterior wall 18' to the left. Also I would like to have the ceiling at the north wall of this shed at 7' sloping up to the existing 8' ceiling. Is this possible? #4.plan Link to comment Share on other sites More sharing options...
solver Posted February 10, 2016 Share Posted February 10, 2016 I don't understand what you want to do. Posting a plan with a room defined -- master bath and closets in your case would make this simpler. Am I close? 1 Link to comment Share on other sites More sharing options...
katalyst777 Posted February 10, 2016 Share Posted February 10, 2016 KB-00367: Drawing a Shed Dormer Manually 1 Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 10, 2016 Share Posted February 10, 2016 Did you turn off 'auto build roof' and raise the 'finished ceiling' after your prior thread? You CAN use the dormer tool to build a shed dormer with 'auto build roof' turned off. You can NOT manually build a dormer with 'auto build roof' turned off. 1 Link to comment Share on other sites More sharing options...
OddBall1958 Posted February 10, 2016 Author Share Posted February 10, 2016 First off I should have Titled this Shed Dormer. My appologies for being ignorant. Am I close? Yes "Solver" that's it! What steps did you take to do it? I followed the "Drawing a shed dormer manually" and that started my problem. It changed the roof line. Should I draw the rooms first then build the dormer? Hello Jo-Ann Yes I followed your instructions in the prior thread. Ok that's probably where I messed up. I backed up a couple of steps and everything went haywire! Now I'm going to play with it some more. Thanks for the input. OK! I've added the rooms to the second floor that need the "Shed Dormer" #4.plan Link to comment Share on other sites More sharing options...
solver Posted February 10, 2016 Share Posted February 10, 2016 I did it in Pro, just so we would have something to talk about. Link to comment Share on other sites More sharing options...
OddBall1958 Posted February 10, 2016 Author Share Posted February 10, 2016 When I use the dormer tool the ceiling goes away. Should I put the ceiling height back to "0" then build the shed dormer the raise the ceiling again or should I leave the ceiling where it is? Link to comment Share on other sites More sharing options...
OddBall1958 Posted February 10, 2016 Author Share Posted February 10, 2016 I got it! Thanks Link to comment Share on other sites More sharing options...
OddBall1958 Posted February 10, 2016 Author Share Posted February 10, 2016 Is it possible to move the front wall of the dormer to where the 4,12 lower roof connects to the upper roof essentially eliminating the 12 12 roof at the bottom of the front wall of the dormer. This would put the dormer wall sitting on top of the lower wall. Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 11, 2016 Share Posted February 11, 2016 How did you create the dormer? Link to comment Share on other sites More sharing options...
OddBall1958 Posted February 11, 2016 Author Share Posted February 11, 2016 With the dormer tool. I did get the front wall to sit on top of the lower wall now. I also tried to create a deck here but I can't seem to get that to happen. It was just the thought of having double doors on the front of the dormer. Link to comment Share on other sites More sharing options...
OddBall1958 Posted February 13, 2016 Author Share Posted February 13, 2016 Is it possible to put a door and deck in front of a shed dormer? Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 15, 2016 Share Posted February 15, 2016 Yes. But...you will not be able to remove the roof eave in front of the door, if you have used the dormer tool to create the dormer. Link to comment Share on other sites More sharing options...
OddBall1958 Posted February 15, 2016 Author Share Posted February 15, 2016 OK! So if I manually build the Shed Dormer it doesn't appear unless I check "auto rebuild roofs" and then my gable ends go away. Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 15, 2016 Share Posted February 15, 2016 Remember what I said about rebuilding the roof again, after raising the ceiling? You needed to lower the ceiling back to where it was when the gables popped up. Also keep checking the outer porch walls on floor 1, because the program sneakily keeps changing the 'in from baseline' setting. The dormer room needs to be kept separate from the 2nd floor (use a room divider wall). The dormer room ceiling should be set to it's finished height, THEN rebuild the roof. Link to comment Share on other sites More sharing options...
OddBall1958 Posted February 16, 2016 Author Share Posted February 16, 2016 Hi Jo_Ann Here is what I've come up with. What's wrong with this picture? Do I need to put a room divider on both sides of the room to stop the walls on the other side from rising up? Is it possible to put the left wall of the shed (in this pic) on top of the wall below? It doesn't have to but just a thought. I would just like to have my original roof line back. Thanks Link to comment Share on other sites More sharing options...
OddBall1958 Posted February 16, 2016 Author Share Posted February 16, 2016 OK I fixed that problem, not that I remember how I did so. So now I've been trying to install a deck and door on the front without any luck. Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 16, 2016 Share Posted February 16, 2016 Your floor plan should look like this. You should not be having any problem building a deck. Attic walls shown have been manually drawn to close the open roof gap next to the deck walls. Set them as 'no room definition'. Link to comment Share on other sites More sharing options...
OddBall1958 Posted February 17, 2016 Author Share Posted February 17, 2016 Do I need wall breaks at the attic walls? Link to comment Share on other sites More sharing options...
OddBall1958 Posted February 17, 2016 Author Share Posted February 17, 2016 OK Im' not getting this. When I put the wall breaks where you have do I delete that section? Then move the dormer wall forward? When I do this the front dormer wall dissappears How are you drawing the attic walls? I've drawn these just like your pic and they don't appear even if I draw a deck there. Sorry for being ignorant. Do I need to back up afew steps like lower the ceiling again? Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 17, 2016 Share Posted February 17, 2016 Skip the attic walls - they are not a necessity. Delete your dormer and start over. Draw 2 side walls as shown - make them gable walls. Draw the room divider wall. Put the 2 wall breaks in - open the wall and set the shed pitch. Open the 'room', and set the ceiling height full height. Draw the 3 railing walls for the deck. Link to comment Share on other sites More sharing options...
OddBall1958 Posted February 17, 2016 Author Share Posted February 17, 2016 Now It's Workin'! Thanks Link to comment Share on other sites More sharing options...
OddBall1958 Posted February 17, 2016 Author Share Posted February 17, 2016 Here is where I'm at. Is the dormer too wide for the deck/balcony to show up? I have it set for the same depth as the other deck. Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 17, 2016 Share Posted February 17, 2016 I have no clue. Mine works. Link to comment Share on other sites More sharing options...
OddBall1958 Posted February 17, 2016 Author Share Posted February 17, 2016 Thanks, I guess I'll keep playing with it. You've been a great help. I appreciate it. Link to comment Share on other sites More sharing options...
