heyseano Posted February 10, 2016 Share Posted February 10, 2016 Hi again A lot of time spent trying to work out little things. Architectural blocks tool bar has gone ?... In the library where is the clothes line....it is in there but under what name ? Sean Link to comment Share on other sites More sharing options...
solver Posted February 10, 2016 Share Posted February 10, 2016 Goto Tools>Toolbars>Customise Toolbars and on the 2nd panel "Toolbar" click the Reset Toolbar button. Can't help with the clothes line. Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 10, 2016 Share Posted February 10, 2016 The block 'cube' doesn't appear until you have 2 items jointly selected. Link to comment Share on other sites More sharing options...
katalyst777 Posted February 10, 2016 Share Posted February 10, 2016 "Explode Architectural Block" is only available for architectural blocks as an edit tool. It isn't available for everything. What were you hoping to be able to use it on?Or were you referring to making an Architectural Block? You'll only have that edit tool if you have applicable things selected (like it you have a Rich Text box selected along with some cabinets, you won't see the edit tool).I don't recall ever seeing a clothesline in the Library Browser (and I have most of the bonus/manufacturer catalogs installed and a search doesn't come up with anything either) so maybe import one from SketchUp?KB-00888: Importing 3D Symbols https://3dwarehouse.sketchup.com/search.html?q=clothesline 2 Link to comment Share on other sites More sharing options...
heyseano Posted February 11, 2016 Author Share Posted February 11, 2016 Hi katalyst In regard to the architectural blocks, I was grouping some kitchen cabinets. I was able to move and rotate but there was no block button, ....the coloured cube. You are probably right re the clothes line....last time I may have simply drawn a square cad box to represent the clothes line rather than a simple library insert. Thanks for your assistance Sean Link to comment Share on other sites More sharing options...
