heyseano Posted February 7, 2016 Share Posted February 7, 2016 Morning folks I am working my way through tutorials the user guide Etc going well with a set of construction plans for a new house and separate flat not too far away. Some where in here is the way to quickly calc the area of the building ??? I need these figure for the building set and also ensure the design is within the allowable limits. Thanking you if you have a simple fix Sean Link to comment Share on other sites More sharing options...
solver Posted February 7, 2016 Share Posted February 7, 2016 The Living Area Label will show this. Preferences>Plan Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted February 7, 2016 Solution Share Posted February 7, 2016 Also in 'Display Options" you can show square footage of each room, interior dimensions, just by checking those layers on or off as you choose. If the "Living Area" is not turned on you can also simply draw a 2D CAD closed poly-line around the area of interest and then select and open the closed poly-line and on it "Poly Line" tab in its dialog box there will be a read out of the poly-lines circumference and Area. DJP Link to comment Share on other sites More sharing options...
heyseano Posted February 8, 2016 Author Share Posted February 8, 2016 Great thanking you David. Solved. Hd pro is addictive!!! Sean Link to comment Share on other sites More sharing options...
