TXRugger Posted January 26, 2016 Share Posted January 26, 2016 Has anyone had the pleasure of designing a gambrel roof whose gable is over a wall comprised of two different sections? The first portion is a full wall and the second section is post and beam above five feet of porch. The roof tool does not recognize the full gable setting over both walls as one so it only creates a simple pitched roof. I have tried installing an invisible wall the combined length of both sections and also tried creating a dummy wall to be erased after roof creation, both to no avail. Anyone have any experience with this? I am using Home Designer Pro 2016. Link to comment Share on other sites More sharing options...
solver Posted January 26, 2016 Share Posted January 26, 2016 Best to attach your plan file. Make sure it's not open in Home Designer. An image showing the problem area will also help. Link to comment Share on other sites More sharing options...
TXRugger Posted January 26, 2016 Author Share Posted January 26, 2016 Here is what I have: Shed.plan Link to comment Share on other sites More sharing options...
Solution solver Posted January 26, 2016 Solution Share Posted January 26, 2016 You have the front and back walls set to Full Gable. Only the end walls should be marked as Full Gable. Fix that and the gambrel roof builds, although I'm guessing you will need to change some settings. Link to comment Share on other sites More sharing options...
TXRugger Posted January 26, 2016 Author Share Posted January 26, 2016 You have the front and back walls set to Full Gable. Only the end walls should be marked as Full Gable. Fix that and the gambrel roof builds, although I'm guessing you will need to change some settings. Thanks. The full gable on the opposing walls was an artifact of switching roof direction. The one thing that I did not have done that is needed in HD Pro is the "Build Roof Planes" check box should be checked to get the refresh of the roof line. It is located in the roof dialogue box. Link to comment Share on other sites More sharing options...
LawB10 Posted January 27, 2016 Share Posted January 27, 2016 When you click Build>Roof the Option box displays clicks Roof styles and then click the one you want to create. A pop up will show with instructions on how to build the roof. Link to comment Share on other sites More sharing options...
