English Posted January 23, 2016 Share Posted January 23, 2016 My garage doors do not have any casings (moldings) on the outside -- just a cased opening to cover the block. I can't seem to get the 3D look that is correct. If I uncheck the exterior casing option the block is exposed (second screen shot). Can anyone help?Thanks Alan PS I should add that I have the same issue with exterior doors. Link to comment Share on other sites More sharing options...
solver Posted January 23, 2016 Share Posted January 23, 2016 That's a long standing bug that only a soffit can squash. You can make the exterior casing 1", add interior casing, and color both to match the trim. This often works. Link to comment Share on other sites More sharing options...
Solution English Posted January 23, 2016 Author Solution Share Posted January 23, 2016 Okay thanks Eric I'll try that Alan Link to comment Share on other sites More sharing options...
English Posted January 24, 2016 Author Share Posted January 24, 2016 I set it to 0" and that had the desired effect. Alan Link to comment Share on other sites More sharing options...
LawB10 Posted January 24, 2016 Share Posted January 24, 2016 I'm trying to figure out what's was problem.... 2 doors were shown, one with the casing, one without, if don't want the space from the door to the driveway, you change the swing side. Link to comment Share on other sites More sharing options...
English Posted January 26, 2016 Author Share Posted January 26, 2016 The two shots show the doors with casing and without. I hadn't thought about changing swing as a garage door only opens one way. I'll try that. Thanks Alan Link to comment Share on other sites More sharing options...
