quesera Posted January 19, 2016 Share Posted January 19, 2016 I have drawn a bathroom in my plan. After drawing the whole room, I then added a WC within it and a shower area behind a glass wall at one end. The room then took on the name WC for the WC end and shows the room name BATH2 for both of the other areas that are divided by a shower wall. When I try to take a wall elevation, it shows each area individually. Is there a way to treat the whole area as a single room and get an elevation for the whole area? I've searched all over the help and can't find anything about this. I have HD Pro 2016. I am attaching a screenshot of the problem, could upload a plan copy if necessary but its big and I'm on a slow link. Thanks in advance for any help you can provide. Link to comment Share on other sites More sharing options...
solver Posted January 19, 2016 Share Posted January 19, 2016 Marking the dividing walls as No Room Definition will let you see everything, but may cause other problems. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 19, 2016 Share Posted January 19, 2016 The wall elevation tool will only display one wall in the room where the camera was created so I would recommend you using the "Full Elevation-Cross Section" camera tool which will show all three spaces at once in elevation. DJP Link to comment Share on other sites More sharing options...
