SAILOR139 Posted January 2, 2016 Share Posted January 2, 2016 I set the overhangs for 16" but some come in at 48" ?? What causes this? How do you fix this? Link to comment Share on other sites More sharing options...
solver Posted January 2, 2016 Share Posted January 2, 2016 It's the way the automatic roof generator works sometimes. You will need to trick it into doing what you want, or upgrade to Pro. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 2, 2016 Share Posted January 2, 2016 To expand on Eric's answer, such mismatches are caused by differing pitches of roofs coming together in concert with the geometry of your plan view wall layout. Also varying ceiling heights can also contribute to that outcome. You can change your roof pitch settings or wall geometry or as Eric said, upgrade to Home Designer Pro for greater control and choice relative to roof design. DJP Link to comment Share on other sites More sharing options...
