sagebrush Posted December 14, 2015 Share Posted December 14, 2015 Does anybody know how to create new Wall Types in Home Designer 2016? I do not see the option Build->Walls->Define Wall Type Link to comment Share on other sites More sharing options...
sagebrush Posted December 14, 2015 Author Share Posted December 14, 2015 Suite, this is my first post 1 1 Link to comment Share on other sites More sharing options...
LawB10 Posted December 14, 2015 Share Posted December 14, 2015 First, draw the wall, then click on it to open it's specification box. In Suite, if you don't choose a template, it will use the default template. The exterior walls will be siding-6, 1 Link to comment Share on other sites More sharing options...
solver Posted December 14, 2015 Share Posted December 14, 2015 Suite lacks the ability to define new wall types. 4 Link to comment Share on other sites More sharing options...
LawB10 Posted December 14, 2015 Share Posted December 14, 2015 Maybe we have a different meaning of wall types as I count 23 in Suite. 1 Link to comment Share on other sites More sharing options...
katalyst777 Posted December 14, 2015 Share Posted December 14, 2015 Like solver said, you can't redefine Wall Types in Suite.You can, however, choose an approximate wall type, like LawB10 suggested.I guess the real question is WHY do you want to redefine the wall types?In your version, you can change the exterior and interior materials of walls, as well as adjust their thickness, which probably covers most situations.If you need to edit how framing is going to be used or set up an actual custom wall type for Materials List purposes, then you'll need to upgrade. 1 Link to comment Share on other sites More sharing options...
