netjcp Posted December 1, 2015 Share Posted December 1, 2015 Hi All, Just starting w/Home Designer Pro 2016. Have a plan pretty much created several rooms and such, however. when I perform the calculate materials for this room, the drywall count seems to be off. For example. I have a bathroom created 8*8.. only 1 wall is an exterior wall and ceilings are 8' tall.. no other options.. but when I select the room, right click and perform calculate materials for this room.. it is only showing me 2 count for 4'*8'*5/8 sheetrock ? Any suggestions... Thought is 4 walls approximately 8' wide.. 8'tall should be at least a count of 8 boards of sheetrock ? Link to comment Share on other sites More sharing options...
katalyst777 Posted December 1, 2015 Share Posted December 1, 2015 The software's Help on that tool says: "A Materials List calculated from a room is created for only the contents of that room: wall materials are not included." 1 Link to comment Share on other sites More sharing options...
netjcp Posted December 1, 2015 Author Share Posted December 1, 2015 Is there a way to get the drywall count for a room ? Link to comment Share on other sites More sharing options...
solver Posted December 2, 2015 Share Posted December 2, 2015 Have you tried the Manual Method? Link to comment Share on other sites More sharing options...
dbneil4056 Posted December 12, 2015 Share Posted December 12, 2015 With all the features that HD Pro offers, I'm surprised that the program can't calculate the amount of sheet rock required for a given area. Anyway, I did use the manual approach with help from an APP on my iPad that I thought might be helpful. It's called Home Builder Pro Calcs. It offers three options for calculating the amount of dry wall sheets and even tells you the required fasteners, joint compound and tape required. The APP has other cost and materials calcs that have come in handy for my budgeting purposes. I recall it costing just a few bucks and well worth the investment. Hope this helps. Link to comment Share on other sites More sharing options...
