SAILOR139 Posted November 29, 2015 Share Posted November 29, 2015 What causes this step in the roof on a 1-1/2 story house? See attachment This has happen several times in the various versions for this 1-1/2 story house design. I have never been able to eliminate it successfully. Kevin E-Perspective Full Overview Image.pdf Kevin E.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 29, 2015 Share Posted November 29, 2015 This is remedied by altering (changing) the ceiling height value either on the second floor and or first floor, changing it gradiently and then after each change, checking the results in an overview camera. What this does is to move the roof planes up or down (by changing the second floor ceiling heights up moves the roof planes up on the second floor or down if you use a lessor value for ceiling heights). You change the ceiling values a little and then check to see if that helped or made worse how the roofs are in relation to each other (first floor to second floor). In Suite, that is the only way you can apply control to the z-axis height of roof planes. DJP Link to comment Share on other sites More sharing options...
LawB10 Posted November 29, 2015 Share Posted November 29, 2015 also make sure second floor walls are aligned with the first floor walls. If not, the software will add 12 inches to first floor room(s) Link to comment Share on other sites More sharing options...
SAILOR139 Posted November 29, 2015 Author Share Posted November 29, 2015 Thanks for the input. David, I tried reducing the ceiling height for the second floor. I had to reduce it to 82" before the step came out. Since the roof over the porch is tied into the main roof I began increasing the height of the porch ceiling; this resolved the step issue. I still had issues with the garage roof integrating with the main roof; I just kept adding and changing attic walls in the garage until it was resolved. The one main roof plane at the garage end should had extended all the way to the garage roof; it doesn't. I haven't been able to force it to do so. In an earlier post I was having trouble with the dormers. I used your suggestion to create them manually. I used a manually created dormer for the front which is split between a stairwell and a bedroom; this work. The back dormer is an automatic dormer which worked fine for this bedroom. Thanks LaeB10, I do check alll my walls; however, I was not aware they change ceiling heights if not align. Thanks Kevin E1.plan Kevin E1-Perspective Full Overview Image.pdf Link to comment Share on other sites More sharing options...
SAILOR139 Posted November 30, 2015 Author Share Posted November 30, 2015 David, I'm retracting my statement about lowering the second floor ceilings. The way I corrected the roof step cause the roof ridge to be off center. I did as you suggested; at ceiling height of 78" the ridge was dead on center and the step was gone. I called for no ceiling and all the rooms appeared OK. Link to comment Share on other sites More sharing options...
LawB10 Posted November 30, 2015 Share Posted November 30, 2015 Here's my version of the plan, It has the dormers.... Kevin E-1.zip Link to comment Share on other sites More sharing options...
Solution SAILOR139 Posted December 1, 2015 Author Solution Share Posted December 1, 2015 My final results. See image. The 2nd floor 78" high; I used soffit per your suggestion to obtain 96" ceiling for images. The garage storage area 56" high; used soffit again. All attic space 95-5/8. The front dormer is manual and the rear dormer is automatic. Both dormers are set back 2' from first floor exterior wall. It appears all exterior and interior images are correct. Thank you for your help! Kevin E3-Perspective Full Overview Image Rear.pdf Kevin E3-Perspective Full Overview Image Front.pdf Link to comment Share on other sites More sharing options...
