dbneil4056 Posted November 28, 2015 Share Posted November 28, 2015 When I create a material list, I get the error attached. I also noticed that if I ignore the error message, there aren't any items listed under the masonry category. Does anyone have an idea as to what might cause this? Thanks! Material List Error.tiff Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 28, 2015 Share Posted November 28, 2015 Do you have a "Monolithic Slab" in your plan? What command did you use to acquire that result exactly? What program title and its version number are you using? Have you watched the provided tutorial videos about "Materials Lists" that are available on the Home Designer website yet? DJP Link to comment Share on other sites More sharing options...
dbneil4056 Posted December 12, 2015 Author Share Posted December 12, 2015 I've been away for a while, so the reason for my delay in replying. I'm using HD Pro 2016 and the command I used was to create a materials list. I did have a monolithic slab chosen for the garage. I unchecked that box and this step eliminated the error. However, when I run the materials list, there is nothing showing for masonry. I do see the foundation walls under general, but that's it. I have attached a copy of my plan in the event it may help locate the problem and suggest a solution. Smith Lake Home Plan copy.plan.zip Link to comment Share on other sites More sharing options...
Solution solver Posted December 12, 2015 Solution Share Posted December 12, 2015 I assume by masonry, you are referring to concrete. Running a materials list shows the following. Link to comment Share on other sites More sharing options...
dbneil4056 Posted December 12, 2015 Author Share Posted December 12, 2015 Thanks - should have caught that one Link to comment Share on other sites More sharing options...
