SAILOR139 Posted November 17, 2015 Share Posted November 17, 2015 Suite I have a multiple floor building with various ceiling heights. It has been a struggle to draw. Now, I'm attempting to revised ceiling heights and floor elevations. In most cases without success. I have revised elevations in the Spec box when it allows it but the walls do not regenerate with the new ceiling heights. Also, in many situations the elevations are greyed out which I don't understand. Why would the software coder block the designer from changing or setting the elevations. That is my choice, not theirs. The s/w package is great but very very frustrating. How can I do the above? Link to comment Share on other sites More sharing options...
solver Posted November 17, 2015 Share Posted November 17, 2015 First, set the defaults correctly Edit>Default Settings>Floor You will need to do this for each floor, so while in plan view, select a floor, then change its defaults. Then Edit>Reset To Defaults Select All Floors and the additional items you want to reset. This may do what you need. If not, post back. Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 17, 2015 Share Posted November 17, 2015 This You Tube video by Dan Baumann addresses "Platforms" in Chief Architect software and may be of help to you: https://www.youtube.com/watch?v=nWibFFtn9Ik DJP Link to comment Share on other sites More sharing options...
SAILOR139 Posted November 17, 2015 Author Share Posted November 17, 2015 It may have. Let me work with my model and see if all other floors are OK Thanks Link to comment Share on other sites More sharing options...
