scott_v Posted September 13, 2015 Share Posted September 13, 2015 How do you guys mark the location of foundation tie downs/anchor bolts on the floor plan view? Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 13, 2015 Share Posted September 13, 2015 When a State Licensed Structural Engineer who is consulting on my project and that person requires the annotation, I commonly create a wall typical that denotes what the consulting Engineer requires. In thirty years of such work, I have yet to work with a Structural Engineer that wanted them shown in plan views. The majority require certain 2D details that show specifics, annotated with text and arrows. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted September 13, 2015 Share Posted September 13, 2015 If you need to locate specific Tie Downs you can use Markers or Callouts like this: Link to comment Share on other sites More sharing options...
scott_v Posted September 13, 2015 Author Share Posted September 13, 2015 If you need to locate specific Tie Downs you can use Markers or Callouts like this: Tie Down Callout.JPG Mick, where can I find Markers and Callouts in the drop downs? Edit: Found them under CAD. Now just have to ficure how to configure them Link to comment Share on other sites More sharing options...
solver Posted September 13, 2015 Share Posted September 13, 2015 Under CAD Link to comment Share on other sites More sharing options...
scott_v Posted September 13, 2015 Author Share Posted September 13, 2015 Great...got it, thanks. Another question: Pro is boxing the rafter bottoms and gable overhang. How do I remove this? Plan attached. From 3D look up beneath eaves and gable overhang. I want the boxing to go away. I want to see the roof sheathing from below all around. test plan R1 9.10.15 .plan Link to comment Share on other sites More sharing options...
Kbird1 Posted September 13, 2015 Share Posted September 13, 2015 uncheck Soffits or set to them 0" thickness (maybe not in Pro ? ) so make soffit material "opening -no material" (invisible) and uncheck Boxed Eave on the Options Tab in the Build roof DBX. PS you may need to Do a Roof Framing rebuild to see the effects of the changes. M. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 13, 2015 Share Posted September 13, 2015 Opened your plan and a couple of things.... What is Code for Garage height were you are ? here it is 15' your's is currently 17'2" so you may need to lower the Pitch Your garage door is not a standard height (84" or 96") , so use an engineered header (3 ply LVL) to squeeze a 8' door in , if needed, however check with your garage door supplier as many are framed to the stated size now , as the casing /frame is actually in front of the door , so your rough opening doesn't need any allowances. You will may need a Low clearance kit for the door too if you go with an 8' door in a 9' foot ceiling garage , once again check with your local supplier. You might want to change your new TD Callout Character height to a scale of 4" for ease of use ...I am not even sure what 4 65/1285th is? use copy and paste then you don't need to fill it in every time.... test plan garage-MH .plan Link to comment Share on other sites More sharing options...
scott_v Posted September 14, 2015 Author Share Posted September 14, 2015 uncheck Soffits or set to them 0" thickness (maybe not in Pro ? ) so make soffit material "opening -no material" (invisible) and uncheck Boxed Eave on the Options Tab in the Build roof DBX. PS you may need to Do a Roof Framing rebuild to see the effects of the changes. M. I had already done all of the above and executed build ceiling and build roof. None of that fixed the problem. I just hit "save" and it re-drew the 3-D. That may work, but you won't find that in the knowledge base...lol. Kinda a weak point in the s/w they don't want to admit to I guess. Link to comment Share on other sites More sharing options...
scott_v Posted September 14, 2015 Author Share Posted September 14, 2015 Opened your plan and a couple of things.... What is Code for Garage height were you are ? here it is 15' your's is currently 17'2" so you may need to lower the Pitch Your garage door is not a standard height (84" or 96") , so use an engineered header (3 ply LVL) to squeeze a 8' door in , if needed, however check with your garage door supplier as many are framed to the stated size now , as the casing /frame is actually in front of the door , so your rough opening doesn't need any allowances. You will may need a Low clearance kit for the door too if you go with an 8' door in a 9' foot ceiling garage , once again check with your local supplier. You might want to change your new TD Callout Character height to a scale of 4" for ease of use ...I am not even sure what 4 65/1285th is? use copy and paste then you don't need to fill it in every time.... test plan garage-MH .plan I drafted the plans for this project on velum and got plan approval and permit a month ago. The shop is in the process of being framed today. The project is a shop and in my jurisdiction that bldg height is allowed with that 9 x 8 door. The 6 x 12 header sits 94 7/8" above the slab. Before the plans were submitted, the panel garage door vendor confirmed that height is within tolerance for the roll up door we're having installed. I'm designing our shop in Pro in order to learn the software. It made sense to see if I could design it precisely to the hand drafted design specs. Link to comment Share on other sites More sharing options...
