BobC_4199 Posted September 10, 2015 Share Posted September 10, 2015 I have a simple question about drawing and using walls where I desire only one side of the wall to be finished. As shown in the attached image, I created a rectangular box in the middle of a room that will enclose mechanical items like HVAC vents, and pipes. The issue I'm having is that HD finishing both sides of the walls with drywall and trim. Other than creating new wall definitions that do not include these items on one side or the other, is there an easy way to tell HD that the enclosed space is 1) not a room, 2) that the walls should not be covered with drywall and no trim, chair rail, crown molding should be applied to these interior surfaces? Thanks in advance for any help or recommendations. Home Designer Pro 2016 Build 17.3.1.1x64 Windows 7 Link to comment Share on other sites More sharing options...
solver Posted September 11, 2015 Share Posted September 11, 2015 Why not just define a new wall type. It's simple as you would be using a copy of an existing wall. You can turn off moldings on a per room basis, but not drywall. 1 Link to comment Share on other sites More sharing options...
BobC_4199 Posted September 11, 2015 Author Share Posted September 11, 2015 Thank you for your suggestion. I am hoping that there is a better (easier) way. I'm sure that this situation comes up in almost every house so I expected that Home Designer would come with such walls already predefined if changing the wall type was the only solution. Since the program didn't come with these walls already defined, I assumed there was an option somewhere to turn on/off the finishing of either side of a wall. Link to comment Share on other sites More sharing options...
solver Posted September 11, 2015 Share Posted September 11, 2015 Just create a copy of an existing wall -- name it something descriptive, then delete one layer of drywall. Done. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 11, 2015 Share Posted September 11, 2015 It's much simpler to do than you think Bob , it'll take longer to read this than actually do it.... -1) open wall definitions on the Build wall Menu and pick the wall type from the drop down box you want to copy ( eg, interior 4) , - 2) hit the copy button , backspace out the Word Copy and put in DWall 1S Only. ( Drywall 1 side Only) - 3) Select the interior Dry wall Layer below -4) and choose Delete , - 5) then ok to close the Wall Defs. DBX (dialog box) these might help too: https://www.homedesignersoftware.com/support/article/KB-00382/modifying-a-wall-type.html http://www.chiefarchitect.com/support/article/KB-02944/defining-a-new-wall-type-in-x7.html 1 Link to comment Share on other sites More sharing options...
LawB10 Posted September 11, 2015 Share Posted September 11, 2015 Click on a wall, open wall specification, and check no room definition. What solver said. Go to the Library click Materials and go from there. Link to comment Share on other sites More sharing options...
BobC_4199 Posted September 11, 2015 Author Share Posted September 11, 2015 Thanks everyone for the help. From all the comments I understand that the process of defining an unfinished area is a manual one requiring the creation of single sided wall types for all types of walls that may be used to form unfinished spaces. Not mentioned in the feedback and not illustrated in my example, I expect that I would have to break walls in order to change wall types when what was a single wall encloses both finished and unfinished areas. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 12, 2015 Share Posted September 12, 2015 Yes Bob , you would need to break your default wall type and change it to the single side Type , unless the single side Type is you default Wall , in which case you would break it to make some of it be finished both sides. M. Link to comment Share on other sites More sharing options...
